MOVIEBUSES
Age: 59 Joined: 24 Sep 2007 Posts: 42 Location: Riverside, Ca
Posted: Fri Apr 03, 2009 9:42 am Post subject: NYCTA 5285 ROLLS OVER ON MYTHBUSTERS |
Hey Guys,
Here is the info on the up coming Mythbusters episode on the Discovery Channel. The bus used for this is a 1973 T6H 5307-A original to Port Authority of NY and NJ #20, LAX #20, Everette Transit #2455. I bought the last remaining glasstops from Everette and 5285 is the only survivor of this fantastic series of buses. Unfortunately, although 5285 is a beautiful bus it is heavily corroded and the entire floor is rotted out and that is why it was chosen for this shoot. This 2 hour special is sure to be the next bus fans newest dvd.
I have some pictures to post but have no idea how to post them here. If someone else would like to post them, please email me off list.
The Mythbusters episode with starring Scott's bus will be on at 9pm on April 8th on Discovery Channel. It is a special 2 hour episode.
08, 9:00 pm
(120 minutes) MythBusters (Season 6 Special)
Demolition Derby Special
TV-PG
It's another feature length episode of Mythbusters and this time the team are on a mission to mash metal. In this 'Demolition Derby' the team have four fables of automotive mayhem guaranteed to bend your fender. |
ripta42 Site Admin
Age: 45 Joined: 15 Apr 2007 Posts: 1035 Location: Pawtucket, RI / Woburn, MA
Posted: Fri Apr 03, 2009 4:09 pm Post subject: |
Photos uploaded (stolen from the GMFishbowl Yahoo! group ) |
Mr. Linsky BusTalk's Offical Welcoming Committee
Joined: 16 Apr 2007 Posts: 5071 Location: BRENTWOOD, CA. - WOODMERE, N.Y.
Posted: Fri Apr 03, 2009 11:51 pm Post subject: |
Some very interesting pictures!
I have often talked about the 'Angle Drive' (a patent sold to Yellow Coach in 1925) associated with the transversely mounted rear engine which was really first put to use in the Yellow models 720 and 735 (Fifth Avenue and Chicago double deckers) in 1935.
Shown below (top) is just such an updated drive train application which, in this case, is on the featured 'New Look' in the movie referenced in the above post.
The steering gear is also fascinating as seen in the lower image.
Photos by Scott Richards of Regional Transit
Mr. Linsky - Green Bus Lines, Inc., Jamaica, NY
Dieseljim Deceased
Posted: Sat Apr 04, 2009 10:21 am Post subject: Bus Photos |
I must confess that, I,too, have bootlegged my share, too, lol. |
Posted: Sat Apr 04, 2009 1:49 pm Post subject: |
In this particular case, you have little to worry about;
I've met Scott Richards and he's a very fine gentleman (it takes one to know one!), and I'm certain that he doesn't mind the use of his images for educational purposes as long as we are kind enough to give him credit.
Mr. 'L' |
MOVIEBUSES
Posted: Sun Apr 05, 2009 11:58 am Post subject: USING MY PHOTOS |
Hey Guys,
You are more than welcome to use any of my photos that I send to any of the groups. It doesnt bother me at all to share my personal stories or pictures as I hope it keeps the interest alive for the younger generation or anyone else that finds pleasure looking at my pictures for info or education. They are only pictures...
I appreciate credit where credit is due but I understand that not all the time a name is remembered. I dont lable my pictures with my name or anything else as of right now
To sum it all up, the pictures were already posted to GMFishbowl, transportation photographers, norcalbusfans and los angeles bus yahoo and google groups. I was looking for someone to post pictures here and it happened....
Thanks guys. I have many other pictures from this shoot and many others but dont know how to post here and even though it has been explained to me a few times, its a bit too much for me.
www.rts-regionaltransitservice.com |
Posted: Sun Apr 05, 2009 8:01 pm Post subject: |
Is that Angle Drive still built in current models of any type? Thanks (from very ignorant Joe) |
Posted: Mon Apr 06, 2009 2:00 am Post subject: |
N4 Jamaica,
That's a good question and I'm completely in the dark on 'state of the art' in drive trains for buses now.
However, I am almost certain that technology has gone far beyond the simple Angle Drives of years ago.
There is something refered to as 'H' Drive as described below which may be what is used today.
A power train assembly having an H-drive configuration is described as having a number of transversely disposed components which transmit drive power from a transversely mounted drive power source to a transversely disposed rear wheel axle via a longitudinally disposed propeller shaft and a conventional axle-mounted differential. The H-drive configuration is ideally suited for use in low floor buses due to its longitudinally compact dimensions, and the resulting significant manufacturing and operating advantages are described. The H-drive configuration takes drive power source torque developed along a vehicle transverse axis, and after a direction changing, folded back arrangement applies the drive torque or power through a right angle gear box to the longitudinal propeller shaft for conventional coupling into the differential.
The wording in the schematic below may be fuzzy but the diagram is clear enough to see the 'H' pattern.
Apparently, this solves a lot of problems on the low floor jobs which comprise most of today's transit fleets.
Diagram courtesy of the U. S. Patent Office.
Jeff406cid
Posted: Wed Apr 08, 2009 5:06 am Post subject: |
N4 Jamaica wrote: | Is that Angle Drive still built in current models of any type? Thanks (from very ignorant Joe) |
I believe it died with the RTS. The use of the Allison world transmission makes it an impossibility, and everything nowadays is using it, from Orion to MCI. The use of the angle drive made the relatively short tail of the RTS possible. Longitudinally mounted drivetrains have a larger overhang, giving it a disadvantage in pulling away from curbs and making worry free turns. .
It's interesting to note how VERY similar the underside of the bus looks like the underside of the MCI classic coach! It really is the same bus under the skin. |
